Circuit diagram of PIC Chip Programmer
This DIY PIC programmer is a continuation of our PIC programming basics tutorial. By using this USB PIC programmer, you can program microchip PIC series of 10F, 12F, 16F, 18F, 24F, 30F. This is also an EEPROM programmer as it supports 12Cxx EEPROM. The main component of this PIC microcontroller programming circuit is a PIC182550 microcontroller which controls the overall circuit. Serial port PIC programmers are the widely used PIC chip programmer Kit, but since laptops have no RS232 ports they require an USB to RS232 converter.
Recommended for you:
Components Required
https://cloud.mail.ru/public/F7R7/Bixu1fGqa
- PIC microcontroller Beginner’s guide: Basic connection circuit
- How to burn or program PIC Microcontroller?
Components Required
- Microcontroller PIC 18F2550
- Transistor (BC548-2Nos, BC547, BC557)
- Diode IN4148(6Nos)
- Resistor(IK-7Nos, 100K, 470-2Nos, 1M, 470K, 330-3Nos)
- Capacitor(0.01uF-3Nos,2.2uF-2Nos, 10uF, 22pf-2Nos)
- Crystal 8MHz
- USB Connector
- 5-Pin Header (2Nos)
- PIC 18F2550 has an inbuilt USB port which makes PC interfacing much easier.
- First a firmware should be burnt to PIC 18F2550 using any PIC programmer and then connect the jumper as in the circuit diagram.[wpdm_file id=3]
- The jumper connection decides the mode of the programmer, i.e. boot loader mode or programmer mode. Boot loader is used to upgrade your firmware and programmer mode is to burn the PIC microchip.
- Next we need software to burn our PIC, USB PIC Prog is suitable for this hardware. Download USB PIC Programmer Software from the following link
- Now connect the circuit to the USB port of your PC and open hex file to PIC programmer software.
- Connect any PIC microchip through the ICSP (In Circuit Serial Programming) Header, it include VPP, VDD, PGD, PGC, GND.
- Now you are done with it. So what are you waiting for? Start burning PIC microcontroller.
