Hex Editor Neo 6.31 Full
Introducing Hex Editor Neo, a versatile tool that allows you to edit anything without exception, without size limitation and faster than any other simillar applications. Hex Editor Neo allows you to edit large files and at high speed, allows you to edit, view, modify, analyze, insert and change the hexadecimal data and binary files with unlimited undo and redo, so you will be easier to edit various hexadecimal data and binary files such as * .exe, * .dll, * .jpg, * .iso even anything you want. Hex Editor Neo Ultimate Full is an advanced file editor with numerous powerful features and highly-optimized tools used to make file editing task quick and simple.
Features:
  • Edit hexadecimal data and binary files
  • Fast to find data patterns from any files
  • Open, view and edit any files and any sizes
  • Optimized for multiple core processor
  • Supports all regular expression search
  • Unlimited undo/redo and all ultimate features
  • And so much more.
Screenshots:
Requirements:
  • Windows XP/Vista/7/8/10 (32-bit/64-bit)
How to install/Activate:
  • Disconnect from internet (most recommended)
  • Extract and install the program (run Setup)
  • Do not launch the program, exit if running
  • Copy Patch into the installation directory
  • “%ProgramFiles%\HHD Software\Hex Editor Neo”
  • Run as admin the patch and click on “Patch”
  • Or just extract and run the portable version
  • Enjoy Hex Editor Neo Ultimate 6.31
http://www.mediafire.com/file/gnnedg4fqzj9g6y/Hex Editor Neo Ultimate 6.31.zip
https://cloud.mail.ru/public/9LrE/Rob1PFFJU
