H
haingoc
Guest
Geometric Technologies: CAMWorks 2011 SP1.1 for SolidWorks x86/x64 (2010/2011) MULTILANG
Geometric Technologies: CAMWorks 2011 SP1.1 for SolidWorks x86/x64 (2010/2011) MULTILANG | 1 Gb
Module CAMWorks allows you to create programs milling, turning, turning, milling and wire erosion process. The following types of machines: milling with simultaneous control of two? five axles;
CNC single and duplex, single or dual piston calipers, with software controlled servo mechanism (tailstocks, lunettes, catchers details ...);
Turning / Milling single and duplex, single or dual piston calipers, with software controlled servo mechanism, with simultaneous control of two? five axles;
Erosion of the two and chetyrehosevye.
Treatment is carried out directly in SolidWorks , and directly on the model of SolidWorks. The results of the programmer are stored in the same model of a part or assembly SolidWorks. This provides full associativity of the model and tool path that leads to the automatic renewal of all the trajectories of the tool during the model changes. When added to the SolidWorks model of any process data, such as signs of roughness, base, tolerances of form and position of surfaces, tolerances on dimensions, engineer programmer always has immediate access to them, which facilitates the selection scheme based on machine parts and the selection needed to ensure the specified quality parts of the tool and cutting conditions. Detail can easily be adapted to the needs of processing by, for example, to eliminate redundant in terms of processing elements of the geometry or by applying to the executive model dimensions in the middle of the tolerance. While working with the SolidWorks assembly can perform a joint processing of multiple parts, program processing a series of parts, or just completely simulate all the real situation on the machine table all of snap in, preparation of any complexity and so on for the most complete account the realities of treatment at the earliest stages New Program
System requirements:
SolidWorks Version 2010 2011 Win32 & Win64, MS Access 2003 2010 32bit only!
Operating System MS Windows XP/Vista/Win7, Server 2003 1932 64bit
Graphics 1024x768 resolution with minimum 32768 colours
Disk Space 10GB free
Memory 1GB RAM (2GB recommended)
http://www.filesonic.com/file/1158148934/CAMWorks.part1.rar
http://www.filesonic.com/file/1158148964/CAMWorks.part2.rar
http://www.filesonic.com/file/1158151974/CAMWorks.part3.rar
http://www.filesonic.com/file/1158148984/CAMWorks.part4.rar
http://www.filesonic.com/file/1158141644/CAMWorks.part5.rar
