H
haingoc
Guest
Geomagic Qualify v12.12-Lz0
Geomagic Qualify v12.12-Lz0 | 700 MB
GeomagicQualify enables fast, accurate, graphical comparisons between digitalreference models (CAD models or scanned physical models) and as-builtparts for first-article inspection, production inspection and supplierquality management. A comprehensive report generator integrates multipleviews including 2D and 3D dimensions, cross sections and GD&Tcallouts, as well as charts and tables in a variety of formats.
Geomagic Qualify Features and Specifications
Scan and align
* Collect point and polygon data from all major 3D scanners, digitizers and hard-probing devices
* Perform inspections with both ordered and unordered data
* Compare as built objects to a CAD model or an average of several scanned models
* Align models using your method of choice (datums, features, reference point system, 3-2-1 or best fit)
* Save, load and apply alignment methods for automated and repeatable inspection
Compare
* Generate 3D color-mapped models to illustrate deviations over an entire part
* Define and modify the color spectrum including segmented color spectrums
* Create Go/No Go graphical reports for easy to read analysis
* Generate deviation whisker plots of model cross sections
Evaluate
* Create 2D and 3D dimensions on cross-sections and selected regions
* Detect and inspect geometrical features such as spheres, planes, cones, cylinders, slots, holes and points
* Calculate size, analyze fit, compare 2D and 3D features, measure point-to-point and feature-to-feature distances and angles
* Create and evaluate GD&T callouts with full control over report display
* Perform industry-specific analyses such as Gap & Flush
Report
* Automatically generate inspection reports in HTML, PDF, Microsoft Word and Excel formats
* Output reports as XML for use with external report engines
* Export CSV and Unicode data for trend analysis and SPC
Automate
* Automate the inspection process from alignment to the generation of inspection reports
* Record steps in the inspection process to inspect multiple parts automatically
* Define macros for automating repetitive tasks
* Repeat, reuse, migrate and adapt existing inspection processes with Automation Designer
* Use a single reference model to perform multiple automated inspections with different steps and options
Geomagic Blade Module (Optional)
* Perform turbine blade alignment using point and line targets that simulate edge-to-pin contact
* Analyze complex turbine blade geometry
* Perform turbine blade 2D twist analysis
* Analyze complicated internal blade geometry
Scan and align
Compare
Evaluate
Report
Automate
http://www.filesonic.com/file/1157786294/19.GeomagicQualify.part1.rar
http://www.filesonic.com/file/1157785754/19.GeomagicQualify.part2.rar
http://www.filesonic.com/file/1157785744/19.GeomagicQualify.part3.rar
