H
haingoc
Guest
Fedora 15 i686/x86_64 (2xLiveCD)
Fedora 15 i686/x86_64 (2xLiveCD) | 1.12 GB
Formallypresented to release Linux-Distribution Fedora 15. Of the keyimprovements Fedora 15 You can mark the transition to the systemmanager systemd, Change the names of network interfaces, integration ofdesktop environment GNOME 3 with obolochnoy GNOME Shell, Assemblingpackets using GCC 4.6, Use Linux-kernel 2.6.1938, Adding theimplementation of a dynamic firewall that involvement by default DNSSECand a move to the directory / run instead of / var / run.
The main innovations introduced in Fedora 15:
User
Integrationof graphics by the GNOME 3 and use the default shell GNOME Shell. Anoverview of innovation GNOME 3 can be found here. Additionally,distribution assemblies are available with graphical environments KDE4.6 and Xfce 4.8;
Use instead of the OpenOffice.org office suite LibreOffice;
The package includes the latest version of the training envelope Sugar 0.92;
Using the Firefox web browser 4, comes with a fully open Java-plugin IcedTea-Web;
Updatethe video drivers: Intel 2.14.0 c support Sandybridge; Radeon 6.14.0with support for 2D, 3D and videoakseleratsii for GPU Evergreen, aswell as 2D and videoakseleratsii for GPU Northern Islands; Nouveau withsupport 2D, 3D and videoakseleratsii for GPU Fermi;
Using X.Org-server 1.10 and prior versions of Mesa 7.11;
Developer
Integrationin the distribution Python 3.2 and newer versions of Rails (3.0.3) andOCaml (3.12). Upgrading the Boost library to version 1.46;
Integration of assembly and management of Java-Maven project 3;
Updating debugger GDB to version 7.3 (release not yet released), the inclusion of a set of compilers, GCC 4.6;
System changes
IntegrationSystem Manager systemd as a system initialization by default. Systemdaimed at more intensive parallelization service execution at bootsystem, having incorporated the best features of systems such aslaunchd (Mac OS X), SMF (Solaris) and Upstart (Ubuntu, Fedora). Inaddition to launching services, systemd provides the functions ofmonitoring of the background processes. Learn more about systemd can befound in previously published reviews (here, here, here, here andhere). Comparison of initialization systemd, upstart and SysVinit canbe found here;
Migrating / run from the directory / var to theroot in order to solve the problem with inaccessibility of / var / runearly in boot.
Changing the names of network interfaces. InsteadethN device names will emerge depending on the type of connectionnetwork adapter: em port - embedded in the motherboard and networkcard pci slot # port - card with PCI-interface.
Switching to GCC 4.6 for packaging;
Improvingthe operation of the power management system, support for automaticallytuning the parameters of the system, to ensure optimal balance betweenperformance and power consumption. Integration Center PowerTOP 2.0 toidentify bottlenecks that lead to increased energy consumption;
Enabling compression system XZ for the formation of Live-enabled images to reduce the size of the image by 10 percent;
Adding LessFS, FUSE-module for the automatic association of duplicates in the files;
UpdateRPM Package Manager to version 4.9, which includes support for plug-ingenerator and built-in dependency filtration generated curves,increased productivity;
Switching to Linux-kernel 2.6.1938.
Inthe installer used on the installation DVD, the menu adds the abilityto install with the file system Btrfs (previously demanded the transferof the special installer options). Separately, the continuation of workon utility btrfsck, designed to restore the integrity of damagedBtrfs-sections, and the improvement of the pluginyum-plugin-fs-snapshot, allowing the system returned to its originalstate after a failed install or upgrade packages. It is reported thatthe developers are considering using Btrfs as the default file systemis already starting with the next release (Fedora 16).
Virtualization and Security
AddingDynamicFirewal, the background process for dynamic management of packetfilter rules via DBus. Using DynamicFirewall will make changes to yourfirewall without having to reboot without breaking the rules andestablished connections. To dynamically control the firewall providedutility firewall-cmd, which greatly simplifies the creation of rules,proceeding not from the IP-addresses of network interfaces and portnumbers, and names of services (for example, to open the service accesssamba for 90 seconds, you can firewall -cmd - enable - service = samba- timeout = 10 ).
In Fedora 16 will create additional graphictools. In the long term (Fedora 17) will implement an interactive modelocking, which in the event of unauthorized external requests fromlocal applications or access from outside to network services, the userdisplays an interactive form with a proposal to accept or reject therequest with the possibility of opening up access only at certain times;
C to enhance security, all setuid-applications will bedowngraded to the capabilities, allows you to selectively organizethe execution of preferred only required action. For example, the pingutility will be able to access only the raw-socket (CAP_NET_RAW),without delegating the remaining root-right;
Integration BoxGrinder,a tool to facilitate the formation of assemblies for deployment withinthe different virtualization (KVM, Xen, EC2);
Improved support forEncrypting File System eCryptfs. Use authconfig to automatically mountthe encrypted portion of your home directory when a user login;
Using the default DNSSEC configurations of workstations. For name in NetworkManager uses DNS-Server BIND;
Technology Support Spice in virt-manager;
GUI-interface Setroubleshoot redesigned to simplify diagnosis of problems with SELinux.
Year: 2011
Title: Fedora
Version: 15
Latest version: 15
Architecture: i686/x86_64
Type of drive: CD
User
Developer
System changes
Year: 2011
Title: Fedora
Version: 15
Latest version: 15
Type of drive: CD
http://www.filesonic.com/file/1158212744/Fedora.15.part1.rar
http://www.filesonic.com/file/1158212344/Fedora.15.part2.rar
http://www.filesonic.com/file/1158208014/Fedora.15.part3.rar
