ESP8266-01Smart Relay for Home Automation
Smart Relay Circuit
ESP8266-01 Code
#include <ESP8266WiFi.h>
const char* ssid = "Circuits DIY";
const char* password = "03433212601";
int RelayPin = 2; // GPIO2
WiFiServer server(80);
void setup()
Serial.begin(115200);
delay(10);
pinMode(RelayPin, OUTPUT);
digitalWrite(RelayPin, LOW);
// Connect to WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
void loop() {
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
while(!client.available()){
delay(1);
// Read the first line of the request
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
// Match the request
int value = LOW;
if (request.indexOf("/RELAY=ON") != -1) {
value = LOW;
if (request.indexOf("/RELAY=OFF") != -1) {
digitalWrite(RelayPin, HIGH);
value = HIGH;
// Return the response
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<h1>IoT Smart Relay</h1>");
client.println("<h4>www.Circuits-DIY.com</h4>");
client.println("<img src=\"https://static.thenounproject.com/png/731364-200.png\">");
client.println("<br>");
client.print("Relay Pin is now: ");
if(value == LOW) {
client.print("On");
} else {
client.print("Off");
client.println("<br><br>");
client.println("<a href=\"/RELAY=ON\"\"><button>Turn On </button></a>");
client.println("<a href=\"/RELAY=OFF\"\"><button>Turn Off </button></a><br />");
client.println("</html>");
delay(1);
Serial.println("Client disonnected");
Serial.println("");
Steps to Install ESP8266 NodeMcu In Arduino IDE
Arduino IDE'de ESP8266 NodeMcu Kurulum Adımları- Navigate to File> Preferences in your Arduino IDE.
- As indicated in the picture below, enter http://arduino.esp8266.com/stable/package esp8266com index.json into the “Additional Boards Manager URLs” section. Then press the “OK” button. If you already have the URL for the ESP32 board, separate the Links with a comma.
- Navigate to Tools > Boards Manager.
- Search for ESP8266 and click the “ESP8266 by ESP8266 Community” install button.
- That’s all. Within a few seconds, it will be installed.
Uploading the Code
- Because it includes a built-in programmer, posting the sketch is quite straightforward. Connect the board to your computer. Check that you have the correct board chosen.
- You must also pick the correct Port.
- In the Arduino IDE, click the “Upload” button and wait a few seconds until you get the message “Done uploading.” in the lower left corner.
