D
dancy1981
Guest
Eplan Cabinet 2.0.5 Build 4291
MULTi | 2010 | 684 MB
Eplan Cabinet - Base module contains all functions for fast and reliable layout of elements on the mounting plate and elektroshafah. With its convenient interface and engineering tools such as Master of the project, all users can quickly and easily master the design layout.
The base module contains all functions for fast and reliable layout of elements on the mounting plate and elektroshafah. With its convenient interface and engineering tools such as Master of the project, all users can quickly and easily master the design layout.
Ducts, mounting rails, terminals, and contactors are easily installed with one click. Interactive system for conflict prevention, as well as the management function of minimum distance and prohibited zones avoid design errors. In addition to the three-dimensional image of the control cabinet by pressing a button you can get all the two-dimensional images that should be included in the manufacturing documentation.
EPLAN Cabinet allows you to accelerate through standardization. As a blank, select already partially equipped with a sample cabinet in accordance with company needs. Thus, the specification will automatically enter control panel and all devices. This is the basis for creating their own system of orders.
Direct interface EPLAN Electric P8 can exchange information about the components and connections. Importing data from other systems, CAE is also not take much time. Thus, data from the projects shall be used directly - error!
System requirements:
PCs based on common standards
Minimum configuration:
Processor: 2.6 GHz
Memory: 1 GB
Hard drive: 160 GB
Video: support for OpenGL, memory 128 MB
Standard configuration:
Processor: Core 2 duo 2,66 GHz)
RAM: 2 GB
Hard drive: 250 GB
Video: support for OpenGL, memory 256 MB
Maximum configuration:
RAM: 3 GB
Hard drive: 400 GB
Processor:
Alternatively, you can use a comparable
single processor, for example. processor, Intel P4D with clock
frequency of 3.0 GHz or 3.8 GHz. However, we recommend that you
above the standard or maximum configuration, as it
has greater relative power, and is based on more
advanced technology.
Mirror:
Processor: 2.6 GHz
Memory: 1 GB
Hard drive: 160 GB
RAM: 2 GB
Hard drive: 250 GB
RAM: 3 GB
Hard drive: 400 GB
Processor:
http://www.filesonic.com/file/1269508391/EPLAN.Cabinet.part1.rar
http://www.filesonic.com/file/1269508601/EPLAN.Cabinet.part2.rar
http://www.filesonic.com/file/1269473084/EPLAN.Cabinet.part3.rar
http://www.filesonic.com/file/1269473134/EPLAN.Cabinet.part4.rar
http://www.filesonic.com/file/1269477404/EPLAN.Cabinet.part5.rar
http://www.filesonic.com/file/1269477444/EPLAN.Cabinet.part6.rar
http://www.filesonic.com/file/1269483404/EPLAN.Cabinet.part7.rar
Mirror:
http://www.wupload.com/file/26953407/EPLAN.Cabinet.part1.rar
http://www.wupload.com/file/26953427/EPLAN.Cabinet.part2.rar
http://www.wupload.com/file/26954206/EPLAN.Cabinet.part3.rar
http://www.wupload.com/file/26953916/EPLAN.Cabinet.part4.rar
http://www.wupload.com/file/26954075/EPLAN.Cabinet.part5.rar
http://www.wupload.com/file/26954263/EPLAN.Cabinet.part6.rar
http://www.wupload.com/file/26954256/EPLAN.Cabinet.part7.rar
