Need 3 resistance 100 OM, 33 OM, 1 kohms, db25 printer, caustic tool-25 watt
How to make cable
Link only 5 of resistance
Bind the wires (not exceeding 15 cm at most)
How to make cable
Dragged the Volt as a picture
Don't forget to paste Jp1 legs together
Cables should be as short as possible on the one hand a db25 Alternatively record 6 to plugins (1-d câble DB25 câble imprimante
Link your jtag cable to the computer (1-d câble DB25 câble ’ imprimante)
Now explain how
First install device JTAG cable
II then installation inst _ giveio
Third open program EJTAG _ TT and then the following counters
Press the Connect button that you want mistakenly catching the taking read as you can only be programmed in the BOT boot if you want to boot ali c. § B Or dump would prefer
