Edision Tools
satytools für alte EDI´s satytools
Features:
-As Loader:
-Upgrade Channel list (compatible with .txt and .bin)
-Read channel list (compatible with .txt and .bin)
-Upgrade firmware, as normal mode, forcing the update and loading MAIN
-Fix err0 easily
-Read firmware through Rs232 (it makes a perfect copy of the entire flash: firm, boot, channel list, settings, ...)
-Download and Upload 8 favorite lists
-Others utilities:
-Divide firms in sectors to load it one by one with the jtag, because sometimes we can't load all firm directly
-Delete or add the header of the firmwares
-Extract One part of the firm: factory data default, firm, boot, background
-Replace the original background of the firm
-Convert channel list beetwen different formats (bin and txt)
-As Channel list editor
-Modify any data in channels, satellites, transponders and antennas
-Create channels/sats/tps/ants in any position (with all properties 0 or as copy of other)
-Delete channels/sats/tps/ants
-Rearrange channels/sats/tps/ants by drag and drop, or sending it to specific positions directly
-Filter channels, by satellite, transponder and name to find them easily
-See the channels with details or as list
-Save one channel list with only one sat from a multisat list
-Join channel lists, for example one with astra and one with hispa, we can do one with astra+hispa
-Edit all list of favorites
-Import list in Mvision format
Languages: Spanish and english
Note:
To use it, is required NET Framework 2.0 of windows. Only download and install
For Windows 98/ME/2000/XP -> Detalles de la descarga: .NET Framework, versión 2.0, Redistributable Package (x86)
For windows XP 64 bits -> Detalles de la descarga: .NET Framework, versión 2.0, Redistributable Package (x64)
(Select the correct language (the same of your windows) before download!!)
History:
-Version 1.0
First Release
edision Caslink version
CasLinkX 1.16B1
CasLinkX basiert auf CasLink, jedoch kann man bei CasLinkX den COM-Port wählen.
Update:
V1.16B1
-enable Irdeto odd key editable.
-add CRW orf key01.
V1.16
-support tps.bin file import.
-del the old tps aes import.
V1.15S
-added Nagra B4U movier
-added the Nagra Card Data editor.
V1.15R
-Fix upgrade 108 error.
V1.15e
-support direct cw
-support aes key from softcam.key
-support aes key from camds
V1.15
-add aes key list
V1.12e-V1.13e
-add nagra2 DigiTV default key.
-add crw MTV Networks default key(only for 1.13).
-add cryptoworks orf & easytv key.
-add cryptoworks key import
V1.12d-V1.13d
-add nagra2 P*****re default key.
V1.12c
-add nagra2 Globecast default key
V1.12b
-add nagra2 Polsat default key
V1.12a
-add nagra2 TVcabo default key
V1.12
-add nagra2 key01
neues Caslink von ichliebe
update:
V1.16B4
-add nagra2 new key
-disable no use funtion
TS Doctor1.0.28
wandeln von TS Formaten ins DVR format um den Edision als MediaPlayer zu verwenden
Unterstützte Eingangsformate:
TS
DVR
M2TS
TRP
TS4
REC
TP0
uvm.
Unterstützte Ausgangsformate:
TS
DVR
MKV (Haali Splitter muß installiert sein)
- Unterstützt jetzt auch Comag SL 100 HD -Edision DVR-Streams!
- NEU: Konvertieren nach MKV oder DVR(Comag-Edision)
- NEU: Unterstützung von Radiostreams
- Unterstützt jetzt auch Kathrein HD TRP- Streams!
- Korrektur von fehlerhaften video_full_range_flags (Farbraum/Colorspace) in DVB-Streams!
- Visuelle Schnittfunktion (Werbung rausschneiden)
- Unterstützt jetzt auch iCord HD M2TS und Technisat TS4 - Streams!
- Packet-Editor und Stream-Filter Tool
Argus_Mini_Background_Patcher_v2.0
Anleitung:
- Suche dir ein Motiv aus und ändere die Größe in einem Grafikprogramm auf
720×576 Pixel (PAL) oder 720x480 (NTSC) und speichere die Datei im "*.bmp"
Format ab
- Öffne das Tool und klicke das Kästchen hinter "Firmware"
- Wähle die Firmware aus die du patchen möchtest
- Klicke das Kästchen hinter "Hintergrund" und wähle dein bearbeitetes Bild aus
- Klicke nun "Patch it!"
- Bestätige 2 mal die Abfragen mit "OK"
- Fertig!
Nun kann die Firmware in euren Receiver geflashed werden. Wollt ihr die Senderliste
erhalten sicherte diese vor dem Flashvorgang auf den USB Stick und spielt ihn nach
dem Flash wieder ein!
