Effect Echo is an electronic circuit that is used to delay sound or make an echo in an audio circuit . Using a circuit of echo is easy enough , we just set on the volume, and gain and trimpot near is rate of 20 K ohm to adjust how the desired echoes. This echo circuit using ic 4558D for additional amplifier and ic PT2399 as a major component that serves to echo , or repeat the sound output on the audio system.
How to use it as follows :
That is initially given the output of the mic input or other equipment. Then turn down the volume, and slowly raised, setting echo effect on the trimpot 20K. If not check back for the damaged to the circuit.
