DPDT Relay Wiring Diagram
This is the diagram below to learn all the pin terminals of a Double Pole Double Throw (DPDT) Relay:
The 2 COIL terminals is where the voltage is placed in order to energize the coil. Place the relay's rated coil voltage on these terminals. The polarity of the voltage does not matter. A positive and negative voltage can be placed on either end. Polarity only matters if a diode is used.
The COM terminal is the common terminal. If the COIL terminals are energized with the rated voltage, the COM and the NO terminals have continuity. If the COIL terminals are not energized, then the COM and the NO terminals have no continuity.
The NC terminal is the Normally Closed terminal. It is the terminal that can be powered on even if the relay doesn't receive any or sufficient voltage to operate.
The NO terminal is the Normally Open terminal. It is the terminal where you place the output that you want on when the relay receives its rated voltage. If there is no voltage to the COIL terminals or insufficient voltage, the output is open and receives no voltage. When the COIL terminals receive the rated voltage or a little under, the NO terminal receives sufficient voltage and can turn on the device on the output.
How to Connect a DPDT Relay in a Circuit
In this article, we go over how to connect a Double Pole Double Throw (DPDT) relay in a circuit.
In order to know how to connect a DPDT relay, you must know what each pin terminal represents and how the relay works.
Terminal Pins
A Double Pole Double Throw Relay comes with 8 terminal points.
The terminals are COIL, COIL, COM, COM, NO, NO, NC, NC.
This correlates to the following in the relay:
Terminal Descriptions
  • COIL- This the is the COIL terminal. These are the terminals where you apply voltage to in order to give power to the coils (which then will close the switch). Polarity does not matter. One side gets positive voltage and the other side gets negative voltage. It doesn't matter which order. Polarity only matters if a diode is used.
  • NO- This is Normally Open switch. This is the terminal where you connect the device that you want the relay to power, when the relay is powered, meaning when the COIL receives sufficient voltage. The device connected to NO will be off when the relay has no power and will turn on when the relay receives power.
  • NC- This is the Normally Closed Switch. This is the terminal where you connect the device that you want powered when the relay receives no power. The device connected to NC will be on when the relay has no power and will turn off when the relay receives power.
  • COM- This is the common of the relay. If the relay is powered and the switch is closed, COM and NO have continuity. If the relay isn't powered and the switch is open, COM and NC have continuity. This is the terminal of the relay where you connect the first part of your circuit to.
Now that we know what each terminal pin represents, we now wire it to a circuit for it to do a real-world function. We're going to connect a Double pole double throw relay to a circuit to light up LEDs. When the relay isn't powered, both the red LED and the DC fan are on,. When the relay is powered, the red LED and the fan shut off and the green LED and the DC motor turn on.
This is the circuit below:
Since the relay is rated for 12V, it should receive 12 volts in order to power on. It may work with less voltage, but 12V is really what it should receive. This goes into either side of the COIL terminals. Even if you switched the positive and negative voltage of the power supply, it should work exactly the same.
The COM terminals of the relay get connected to the first part of the circuit. If there is no first part of the circuit, this terminal can be left open. In this case, the first part of the circuit is the 5-volt power supply and the 9-volt power supply to light the LEDs and the DC fan and DC motor.
The NC terminals of the relay get power even when the relay isn't powered. This means that as long as the 5-volt power supply is on, the red LED and the DC fan will be on and operating.
The NO terminals of the relay get power only when the relay is powered. When the relay receives 12 volts of power, the relay snaps from the NC position to the NO position. The red LED and the DC fan now shut off and the green LED and the DC motor now turn on and operate.
