Dev-C++
Bloodshed Dev-C++ is a full-featured Integrated Development Environment (IDE) for the C/C++ programming language. It uses Mingw port of GCC (GNU Compiler Collection) as it's compiler. Dev-C++ can also be used in combination with Cygwin or any other GCC based compiler.
Features are :
- Support GCC-based compilers
- Integrated debugging (using GDB)
- Project Manager
- Customizable syntax highlighting editor
- Class Browser
- Code Completion
- Function listing
- Profiling support
- Quickly create Windows, console, static libraries and DLLs
- Support of templates for creating your own project types
- Makefile creation
- Edit and compile Resource files
- Tool Manager
- Print support
- Find and replace facilities
- CVS support
Source code : Delphi 6 Source code of Dev-C++ is available for free under the GNU General Public License (GPL)
Authors : Colin Laplace, Mike Berg, Hongli Lai : Development
Mingw compiler: Mumit Khan, Jan Jaap van der Heidjen, Colin Hendrix and GNU coders.
System : Windows 95/98/NT/2000/XP
Status : Free Software (under the GNU General Public License)
Bloodshed Dev-C++ Windows için hazırlanmış komple bir derleyicidir. GCC, Mingw veya Cygwin derleyici ve kitaplık setlerini kullanmaktadır, çok gelişmiş özellikleri bulunan, Türkçe dil desteği içeren ücretsiz bir C, C++ yazılım editörüdür.
http://www.fileswap.com/dl/TQXiwl3qL2/Dev-Cpp_5.3.0.3_TDM-GCC_x64_4.6.1_Setup_uydudoktoru.zip.html
Dev-Cpp 5.3.0.3 TDM-GCC x64 4.6.1 Setup_uydudoktoru.zip
