DC-AC invertör şeması
Parts List:
R1 = 10K
R2 = 100K
R3 = 100 ohm
R4 = 50K potmeter, Lin
C1,C2 = 0.1uF
C3 = 0.01uF
C4 = 2700uF
Q1 = TIP41A, NPN
Q2 = TIP42A, PNP
L1 = 1uH
T1 = Filament transformer, your choice
This DC-to-AC inverter schematic produces an AC output at line frequency and voltage. The 555 is configured as a low-frequency oscillator, tunable over the frequency range of 50 to 60 Hz by Frequency potentiometer R4.
The 555 feeds its output (amplified by Q1 and Q2) to the input of transformer T1, a reverse-connected filament transformer with the necessary step-up turns ratio. Capacitor C4 and coil L1 filter the input to T1, assuring that it is effectively a sine wave. Adjust the value of T1 to your voltage.
Input voltage is anywhere from +5V to +15Volt DC, adjust the 2700uF cap's working voltage accordingly.
Replacement types for Q1 are: TIP41B, TIP41C, NTE196, ECG196, etc. Replacement types for Q2 are: TIP42B, TIP42C, NTE197, ECG197, etc. Don't be afraid to use another type of similar specs, it's only a transistor... ;-)
If the whole thing is working, good. If not, relax and don't get frustrated. Do the following checks:
1) You have connected the filament transformer in REVERSE yes?
2) If not, disconnect the power and reverse. If you have, disconnect the transformer and measure the voltage after L1 and ground.
3) Just in case, GROUND for this circuit is same as negative (-).
4) Q1/Q2 are oposites, e.i. npn/pnp.
5) Is your 555 perhaps defective? Check pin 3 for a pulse.
6) Check your transistors to make sure they are not defective.
Çevirisi
Bu DC-AC invertör şeması, hat frekansında ve gerilimde bir AC çıkışı üretir. 555, Frekans potansiyometresi R4 ile 50 ila 60 Hz frekans aralığında ayarlanabilen düşük frekanslı bir osilatör olarak yapılandırılmıştır.
555, çıkışını (Q1 ve Q2 ile yükseltilen) gerekli yükseltme dönüş oranına sahip ters bağlı bir filaman transformatörü olan T1 transformatörünün girişine besler. Kondansatör C4 ve bobin L1, T1'e girişi filtreleyerek etkin bir sinüs dalgası olmasını sağlar. T1 değerini voltajınıza göre ayarlayın.
Giriş voltajı +5V ile +15Volt DC arasında herhangi bir yerdedir, 2700uF başlığının çalışma voltajını buna göre ayarlayın.
Q1 için değiştirme türleri şunlardır: TIP41B, TIP41C, NTE196, ECG196, vb. Q2 için değiştirme türleri şunlardır: TIP42B, TIP42C, NTE197, ECG197, vb. .. ;-)
Her şey çalışıyorsa, iyi. Değilse, rahatlayın ve sinirlenmeyin. Aşağıdaki kontrolleri yapın:
1) Filament trafoyu TERS olarak bağladınız evet?
2) Değilse, gücü kesin ve ters çevirin. Varsa, trafonun bağlantısını kesin ve L1 ve topraklamadan sonraki voltajı ölçün.
3) Her ihtimale karşı bu devre için TOPRAK negatif (-) ile aynıdır.
4) Q1/Q2 zıttır, e.i. npn/pnp.
5) 555'iniz arızalı olabilir mi? Pim 3'ü darbe için kontrol edin.
6) Arızalı olmadıklarından emin olmak için transistörlerinizi kontrol edin.
Parts List:
R1 = 10K
R2 = 100K
R3 = 100 ohm
C1,C2 = 0.1uF
C3 = 0.01uF
C4 = 2700uF
Q1 = TIP41A, NPN
Q2 = TIP42A, PNP
L1 = 1uH
Çevirisi
