Create a Custom Callback Function
If you have an action requiring a status dialog, but the standard status dialog (StatusDlg) is not sufficient, it is possible to create a custom callback function for those actions requiring one.
As an example, we will use a custom callback function to show the progress of a file download:
Note: ShowStatusWindow() shows the status window and sets the title. DownloadStatus() is the custom callback function, and is called by HTTP.Download.
--ShowStatusWindow shows the status window, and sets the dialog's icon
function ShowStatusWindow()
-- Show the Status Dialog
StatusDlg.Show(MB_ICONINFORMATION, false);
-- Show the cancel button
StatusDlg.ShowCancelButton(true, "Stop Download");
end
--DownloadStatus is the callback function to be used.
function DownloadStatus (BytesRead, FileSize, TransferRate, SecondsLeft, SecondsLeftFormat, Message)
-- Set the status meter's range
StatusDlg.SetMeterRange(0, Math.Floor(FileSize/1024));
-- Set the meter position
StatusDlg.SetMeterPos(Math.Floor(BytesRead/1024));
-- Check if the cancel button was pressed
if StatusDlg.IsCancelled() then
-- Cancel button was pressed. Hide status dialog and terminate download
StatusDlg.Hide();
return false;
else
-- Cancel button was not pressed, determine message to be displayed
if FileSize == 0 then
-- Display 'size unknown' message
StatusDlg.SetStatusText("Size Unknown (" .. Math.Floor(BytesRead/1024) .. "kb downloaded so far)");
elseif FileSize > 0 then
-- Display 'downloaded of total' message
StatusDlg.SetStatusText("Downloaded " .. Math.Floor(BytesRead/1024) .. " kb of " .. Math.Floor(FileSize/1024) .. " kb");
end
-- Determine if end of download was reached:
-- Message will = "", the end of the download is a 'busy' state
-- BytesRead will be > 0, because more than 1 byte will have been transferred
-- BytesRead will = FileSize, unless FileSize is unknown (0)
if (Message == "") and (BytesRead > 0) and (BytesRead == FileSize or FileSize == 0) then
-- The download has completed, hide the status dialog and display complete message
StatusDlg.Hide();
Dialog.Message("Download Complete", Math.Floor(BytesRead/1024) .. " kb have been downloaded");
return false;
else
-- The download has not ended, continue to download
return true;
end
end
end
-- Call the ShowStatusWindow() function
ShowStatusWindow();
-- Download the file using a callback function
HTTP.Download("http://www.yourdomain.com/download_folder/file.ext", "c:\\file.ext", MODE_BINARY, 20, 80, nil, nil, DownloadStatus);
