CMOS Logic Entegreler
4001Quad 2-input NOR gate
4002Dual 4-input NOR gate
4006CMOS 18-Stage Static Shift Register
4007Dual Complementary Pair and Inverter
4011Quad 2-Input NAND Buffered
4013Dual D-Type Flip-Flop
40148-bit static shift register
4015Dual 4-bit static shift register
4016Quad Analog Switch/Quad Multiplexer [127kb]
4017Decade Counter/Divider
402014-stage binary counter
40218-bit static shift register
4022Divide-by-8 Counter/Divider with 8 Decoded Outputs [95kb]
4023Triple 3-input NAND gate
40247-stage binary counter
4025Triple 3-input NOR gate
4026DEC. COUN./DIVIDER WITH DECODED 7-SEG. DISPLAY OUTPUTS
4027Dual J-K Master/Slave Flip-Flop with Set and Reset
4028BCD to Decimal Decoder [216kb]
4029Binary/Decade Up/Down Counter [165kb]
4030Quad EXCLUSIVE-OR Gate
404012-Stage Ripple-Carry Binary
4041Quadruple true/complement buffer
4043Quadruple R/S latch with 3-state outputs
4044Quadruple R/S latch with 3-state outputs
4046Phase-Locked Loop [185kb]
4047Low Power Monostable/Astable Multivibrator
4049Hex Inverting Buffer
4050Hex Non-Inverting Buffer
4051Single 8-Channel Analog
4052Differential 4-Channel Analog
4053Triple 2-Channel Multipl/Demul
4054DISPLAY DRIVER
4055DISPLAY DRIVER
4056DISPLAY DRIVER
4059Programmable divide-by-n counter
406014-Stage Ripple-Carry Binary C
4066Quad Bilateral Switch
4067Cmos Analog Multiplexer / Demultiplexer
40688-input NAND gate
4069Hex Inverter
4070Quad 2-Input EXCLUSIVE-OR Gate
4071Quad 2-input OR gate
4072Dual 4-input OR gate
4073TRIPLE 3 INPUT AND GATE
4075Triple 3-input OR gate
4077Quad 2-Input EXCLUSIVE-NOR Gate
4081Quad 2-Input AND Gate
4082Dual 4-input AND gate
4093Quad 2-Input NAND Schm.Trigger
40948-Bit Shift Register/Latch with 3-STATE Outputs
4104Quad Low-to-High Voltage Translator with 3-State Outputs
4502Strobed hex inverter/buffer
4510Edge-triggered synchronous up/down BCD counter with a clock input
4511BCD-to-7-Segment Latch Decade Driver
45128-Input Multiplexer (3-State)
45144-Bit Latched/4-to-16 Line Decoder
45154-Bit Latched/4-to-16 Line Decoder
4516Binary Up/Down Counter
4517Dual 64-Bit Static Shift Register
4518Dual BCD Counter
4519Quad 2-Input Multiplexer
4520Dual Up Counter
452124-Stage Frequency Divider and Oscillator
4526Programmable 4-Bit Binary Down Counter
4528Dual Retriggerable Monostable Multivibrator with Reset
45328-Input Priority Encoder
4538Dual Precision Monostable
4541Programmable Timer
4543BCD to 7-Segment Latch/Decoder/Driver with Phase Input
45533-Digit BCD Counter
4555Dual 1-to-4 Line Decoder/Demultiplexer
4556Dual 1-of-4 Decoder/Demultiplexer
45571-to-64 Bit Variable Length Shift Register
4583Dual Schmitt Trigger
4584Hex Schmitt trigger
45854-Bit Magnitude Comparator
4750Frequency Synthesizer
4751Universal Divider
47948-Stage Shift-and-Store Register LED Driver
489412-Stage Shift-and-Store Register LED Driver
4938Dual Retriggerable Precision Monostable Multivibrator with Reset
40098Hex Inverting Buffer (3-State)
40106Hex Inverting Schmitt-Trigger
40174Hex D-type flip-flop with reset; positive-edge trigger
40175Quad D-type flip-flop with reset; positive-edge trigger
401934-Bit Up/Down Binary Counter
40240Buffer/Line Driver; Inverting (3-State)
40244Buffer/Line Driver; Non-Inverting (3-State)
40373Octal D-Type Transparent Latch (3-State)
40374Octal D-type flip-flop; positive-edge trigger (3-state)
