H
haingoc
Guest
CEI EnSight Gold 9.2.2a
CEI EnSight Gold 9.2.2a | 560MB
Computational Engineering International (CEI) develops cutting-edge visualization and animation software. With CEI's high-end software products, you can expand your simulation process to new extremes. Call it what you want - cutting edge, leading edge or bleeding edge - you're there, with problems of a size and complexity that nobody thought possible a few years ago. Fortunately, there's a tool for those who live on the frontiers of scientific and engineering visualization. It's EnSight Gold, software for analyzing, visualizing and communicating high-end scientific and engineering datasets. EnSight Gold takes full advantage of parallel processing and rendering, provides support for an array of VR devices, and enables real-time collaboration.
EnSight Gold stakes out the territory where models contain millions and even billions of nodes. Which means you have some good company out on the frontier.
"With EnSight Gold on the RAVE, a detailed model of an intricate structure with many components, such as a jet engine, can be viewed from all angles and diverse vantage points. We can now bring our data visualizations more 'out of the screen' than before. It is surprising how much better you can understand complex phenomena when you have more control over how you view it." Jay Horowitz, Visualization Manager, NASA Glenn Research Center VR Lab
Big Performance
EnSight Gold's distributed architecture handles scientific and engineering analysis models containing up to billions of nodes while optimizing memory use. It builds upon the full functionality of CEI's EnSight, used by more than 1,500 scientists and engineers worldwide.
Features unique to EnSight Gold include:
* SMP parallel processing support for more than 2 processors.
* Supports multi-pipe display to drive VR planar and non-planar display environments such as a RAVE or multi-panel display wall.
* "Heads Up" Macro (HUM) for creating customized VR interfaces as well as interaction using VR input devices for head tracking and manipulation.
* Server-of-server (SoS) functionality for parallel processing of decomposed data on SMP or DMP architectures.
* Output to POV-Ray ray-tracing program for photorealistic images.
* Collaboration between remote users.
* Interfaces with EnLiten Gold for sharing of results in VR environments.
* Support for 3D input devices by Trackd or write your own using CEI's provided API.
Big Performance
http://www.filesonic.com/file/1168720024/CEI.ENSIGHT.part1.rar
http://www.filesonic.com/file/1168723214/CEI.ENSIGHT.part2.rar
http://www.filesonic.com/file/1168699444/CEI.ENSIGHT.part3.rar
