cancheck on blaupunkt radio
i hope that someone here can give me an hand.
I have a blaupunkt radio car.
MODEL: ALFA947 GTA MP3 SB05
SN: BP635769345313
FIAT NR. 156 074 559 0
I have the code for that, but since i'm tryng to install it on a car that does not have the BODY COMPUTER, the radio tell me CAN CHECK and stop there..
I cannot find nothing for this model, i can post photos and dump of the memory M95320 ( 25C320)
I would know if someone knows how to decode this dump
(i think that should be similar to other FIAT radio car, even if this was on an ALFA 147 car)
Dump is in attachment
are 2 types of alfa937
one with code in eeprom 95320 other with code in MCU HC11PA8
both can be unlocked, also can be removed im*o protection
This is the tool used for fiat radio cancheck this is a demo by TMW eletronics, but i know there is a cracked version out there. Does anyone have it to share.
arkadaşlar herşey için teşekkürle ama bu cihazın teybe baglantısı nasıl olacak resim var her şey var ama teybe nasıl baglanacak
yardımcı olursanız sevinirim yoksa bu bilgilerin hiç anlamı yok kolay gelsin
resimde işaretli olan malzeme eeprom zaten mesajdaki programı eeprom yükleme makinesi ile bu parçaya yükleyeceksiniz bunu yapabilmek içinde resimdeki parça sökülecek
