CAMWorks 2011 SP1.1 for SolidWorks x86/x64 (2010/2011) MULTILANG ? CWz
  • Konuyu başlatan Konuyu başlatan doremon866
D
doremon866
Guest
CAMWks 2011 SP1.1 f SolidWks x86/x64 (2010/2011) MULTILANG - CWz |1 Gb
Module CAMWks allows you to create programs milling turning turning milling and wire erosion process. The following types of machines: milling with simultaneous control of two* five axles.Treatment is carried out directly in SolidWks and directly on the model of SolidWks. The results of the programmer are sted in the same model of a part assembly SolidWks. This provides full associativity of the model and tool path that leads to the automatic renewal of all the trajecties of the tool during the model changes. When added to the SolidWks model of any process data such as signs of roughness base tolerances of fm and position of surfaces tolerances on dimensions engineer-programmer always has immediate access to them which facilitates the selection scheme based on machine parts and the selection needed to ensure the specified quality parts of the tool and cutting conditions. Detail can easily be adapted to the needs of processing by f example to eliminate redundant in terms of processing elements of the geometry by applying to the executive model dimensions in the middle of the tolerance. While wking with the SolidWks assembly can perfm a joint processing of multiple parts program processing a series of parts just completely simulate all the real situation on the machine table - all of snap-in preparation of any complexity and so on - f the most complete account the realities of treatment at the earliest stages New Program.
System requirements:
SolidWks Version 2010-2011 Win32 & Win64 MS Access 2003-2010 32bit only!
Operating System MS Windows XP/Vista/Win7 Server 2003 - 1932 - 64bit
Graphics 1024x768 resolution with minimum 32768 colours
Disk Space 10GB free
Memy 1GB RAM (2GB recommended
DOWNLOAD:
http://www.filesonic.com/file/1220164554/CAMWks.part1.rar
http://www.filesonic.com/file/1220168624/CAMWks.part2.rar
http://www.filesonic.com/file/1220168554/CAMWks.part3.rar
http://www.filesonic.com/file/1220169044/CAMWks.part4.rar
http://www.filesonic.com/file/1220159621/CAMWks.part5.rar
mirror:
http://www.fileserve.com/file/4RQHkEJ/CAMWks.part1.rar
http://www.fileserve.com/file/XxTJbbC/CAMWks.part2.rar
http://www.fileserve.com/file/bPFK5fD/CAMWks.part3.rar
http://www.fileserve.com/file/Dxdetp8/CAMWks.part4.rar
http://www.fileserve.com/file/hyS4HAu/CAMWks.part5.rar
