BLY88 20Waat Osilator Kontrollü FM Verici
Devrenini Şeması
1604605010238.pngIt's stable and has output of 15-18 watts. This enough to terrorize your wide surroundings at the fm-band.
The most often used technique to connect the components to each other is soldering them on a double sided copper-board.
Another way is connecting the components floating. It is cheaper but very tricky. Below you see the copper-board layout
(PCB). I designed it looking closely at the root scheme.
Devrenin Komponentleri yerleştirilmiş Baskı Devresi
Devrede kullanılan malzemelerin sembolleri
Devrenin Baskı Devresi
Devrenin Malzeme Listesi
    949 bayt · Görüntüleme: 2
Yazar: guclusat
Makale başlığı: BLY88 20Waat Osilator Kontrollü FM Verici
