AZBox Key Tool
Edit or Create Key.bin files for Multicas
Import/Export SoftCam.Key files
Import/patch emu_module's
Copy & Paste support in the editor.
Plain text editor with auto formatting, it can be simply used for SoftCam.Key files if you want to.
Get it here [AZKeyTool]
Not for illegal use, and contains nothing illegal. Program does not contain keys, its simply an editor. Program is freeware, no warranty or support.
Works on XP and Vista
v1.0.18
* First release
* Fixed some errors it encounted with some softcam.key files
- Still not sure it will catch every eventuallity.
* Fixed file dialog cancel errors.
* Fixed program termination, now leaves task manager on exit.
* Added Tool - Discover emu_module settings.
- this discovers emu_module internals and writes a small settings file
- to "<program>"\discover directory so that when you try and patch or import
- this emu_module in the future, the tool can do it automatically.
- so far its creating a unique ID for each module but this might not last.
- if it errors in the future, deleting old discovery files and starting again
- should fix the problem.
