Product Name: AutoPlay Media Studio 8
Version: 8.5.3.0
Release Date: October 10, 2018
Yeni sürüme yapılan değişiklikler
Getting Started
Thank you for using AutoPlay Media Studio! The best way to get started quickly is to read the user's guide within the help file. A shortcut to the help file is located in the Start menu under Start -> Programs -> Indigo Rose Corporation -> AutoPlay Media Studio 8.
You can also access the user's guide from within AutoPlay itself, by choosing Help > User's Guide from the program menu.
Release History
8.5.3.0 - October 10, 2018
Version: 8.5.3.0
Getting Started
Release History
- Feature: Enhanced the security of the commercial version's data file.
- Fix: Fixed a bug where the 'BackColor' format setting was not working in the 'RichText.GetSelectionFormat' and 'RichText.SetSelectionFormat' actions.
- Fix: Fixed a bug where the CFU_UNDERLINEDOTTED 'UnderlineType' was not working on Rich Edit 3.0 or later versions as documented in the 'RichText.GetSelectionFormat' and 'RichText.SetSelectionFormat' actions.
- Fix: Fixed a bug where some paragraph settings weren't working on Rich Edit 3.0 or later versions in the 'RichText.GetParagraphFormat' and 'RichText.SetParagraphFormat' actions.
- Fix: Fixed a bug in the 'File.Install', 'File.Copy' and 'File.Move' actions where if the source file and destination file were the same, the source file would be deleted.
- Fix: Added a check and error message to the ISO Image and Burn Data publishing options for files within the project that exceed the 4 GB limit for ISO9660/Joliet.
- Fix: Fixed a bug in 'IRScriptEditor.exe' where if you clicked on the keyword tooltip in the editor a crash would occur. Updated version to 2.0.1003.0.
