Autodesk EAGLE Premium 8.3.2 (x64)
Autodesk EAGLE Premium 8.3.2 (x64) | 105 MB
PCB design made easy. Make anything with EAGLE PCB design software. Powerful, easy-to-use tools for every engineer. Speed through complex board layouts with modern PCB routing tools. Quickly reuse subcircuits that remain synchronized between schematic and PCB.
Escape your ball grid arrays (BGA) in seconds, not hours.
PCB layout software for every engineer
Bring your electronic inventions to life with a complete set of PCB layout and schematic editing tools in EAGLE software.
Modular design blocks (New!)
Reuse existing blocks of circuitry in a snap.
Multisheet schematics
Keep designs of any size organized and in order.
Electrical rule checking
Have confidence in your schematic design.
Real-time design synchronization
Stay in-sync between schematic and PCB layout.
Easy-to-use schematic editor
Transform your ideas into reality with intuitive schematic capture.
New routing engine (New!)
Design beautiful PCB layouts fast.
BGA fanout (New!)
Escape from your BGA in seconds.
Simplified selection and editing (New!)
Select, group, and edit your design, your way.
Assembly variants
Make one design and assemble many with variants.
High-speed design
Design with the latest technologies, including DDR4, PCI Express, or USB-C.
Design rule checking
Ensure your boards are ready to build.
Powerful PCB layout
Bring your design to life with intuitive PCB layout tools.
3D models
Unite your PCB and enclosure together.
Complete components
The one-stop shop for reviewing your component needs.
Manufacturable parts
Reduce worries about parts availability.
Accessible library content
Thousands of ready-to-use part libraries.
One-click make
Generate your CAM outputs with a single click.
One-click MCAD
Fast track your designs to your mechanical tool.
User Language Programs (ULPs)
Improve your design tool process.
EAGLE Premium
Includes 999 schematic sheets, 16 signal layers, and unlimited board areas.
- Microsoft® Windows® 7 or newer is required.
DOWNLOAD
rapidgator
nitroflare
uploadgig
depfile
uploaded
turbobit
Autodesk EAGLE Premium İndir 8.6.3
Autodesk EAGLE Premium İndir 8.6.3 x64
Autodesk EAGLE Premium,
ile PCB düzeninin ve şematik düzenleme araçlarının eksiksiz bir setiyle elektronik buluşlarınızı hayata geçirebilecek ve çeşitli devre tasarımları oluşturabileceksiniz. Kullanıcı dostu bir arayüze sahip olan bu program ile şematik tasarımları hızlı ve kolay bir şekilde tasarlayabilecek ve tasarımlarınıza
çeşitli montajlar yaparak sanal ortamda test edebileceksiniz.
Boyut: 109-mb
