AUDIO SIGNAL TO LIGHT USING LARGE SIZE 200W HALOGEN LAMP
Konusu 'Amplifikatör Devreleri' forumundadır ve guclusat tarafından 10 Ağustos 2018 başlatılmıştır.
    Audio Signal to light project is an audio to light modulator, which controls the intensity of light in response to an audio input. This project is ideal for dance parties, DJ, Discotheques etc.
    • Input: Standard Audio signal input from Speaker
    • AC Mains Power supply: 230 VAC or 110 VAC
    • Load : 200 W
    • Input isolated with the use of Opto-coupler
    • Onboard Presets to adjust level
    • Terminal pins for connecting audio input
    • Four mounting holes of 3.2 mm each
    • PCB dimensions 36 mm x 50 mm
    [​IMG] [​IMG] [​IMG]
