O
omega
Guest
Artlantis Studio 3.0.6.0 Portable
Artlantis Studio 3.0.6.0 Portable | 378.21 MB
Artlantis is recognized as the fastest, most powerful solution for photo-realistic 3D rendering and animation. Now, Artlantis 3 is strengthening its lead with an even more accurate radiosity engine, new management of geometry by layers, better management and enrichment of media, and simplified control of optimized lighting. In addition to its many import plug-ins, which are now compatible with the Autodesk 2010 product line, Artlantis 3 now benefits from a new technology for export plug-ins. This new feature which is available in the OBJ, FBX, U3D, DWF, and SKP formats, integrates Artlantis into the complete design process.
n process.
Editable Anchor Points
The anchor point allows you to place and rotate an object or component in the 3D scene. Grab this point in the 2D view by pressing
the âDâ key, and simply drag it to the desired location.
Media Search Function
When opening a file, Artlantis 3 allows you to search for and replace any missing media components on your hard drive, as well as
delete them.
Media
The richness of the online Artlantis gallery eloquently demonstrates that media play a key role in projects andâ¦in Artlantis 3 with
new developments, new shadersâ¦
Transparency of Billboards and Plants
Accessible directly in Artlantis, the new transparency slider allows you to set the transparency of billboards and 3D plants in
order to better view the project. Thereâs no longer any need for photo editing!
Detachable Components
Detach elements of the 3D model and keep them as internal components in your 3D scene using the polygon selection tool. This
component is easy to handle as an external object (aof) while remaining fully integrated in the scene.
Layers
The continuous development of media (currently several thousand) has focused our interest on their management, and on the handling
of geometry in 3D scenes.
Layer Management
Artlantis 3 has a new structure of layers: scene, objects, 3D plants, lamps, animated objects and billboards. You can also add or
remove your own layers.
Automatic Placement
The âdefault layerâ function allows you to determine the destination layer for each type of media. Once you add new billboards or
objects to your projects, you can have this placement done either automatically or manually.
Layer Import
ArchiCAD users will appreciate this new feature, which, thanks to the ArchiCAD export plug-in, allows you to select the layers you
want to export to Artlantis.
Visibility by View
For greater ease of use and increased productivity, especially on large projects, hide the layers that might burden your work in
preview (for example, 3D plants). Whatâs more, this new function also allows you to present your various layout options from the
same document.
Lights
Fall-off Presets
Artlantis 3 offers 9 different types of lighting accessible by a drop-down menu (Lights inspector). Based on an adaptation of
photometric data of light sources, these lighting options can be completely customized: change the intensity, the color, the angle,
the softness of shadowsâ¦
Neon Shader
The Neon shader has also been greatly improved both in terms of quality and rendering speed.
Radiosity
This brand new rendering engine, developed especially for architecture, is faster and more accurate than ever before. No other
product on the market matches Artlantis 3âs radiosity engine in rendering speed and precision.
Exceptional Quality
In general, the quality of the renderings has been greatly improved. Abventâs R&D team has paid special attention to the likeness
between the preview and the final rendering.
Complete Settings
Pre-defined settings for both interior and exterior scenes make life easier for beginners, while more advanced users will
appreciate the âExpertâ interface, which allows them to personalize the radiosity settings.
Animation
(Artlantis Studio)
Clouds
In an ongoing quest for realism, Artlantis Studio invites you to animate clouds by activating the windâs parameters, the direction
and speed of which you can choose in the heliodon inspector.
Water
A plain cursor is all you need to add movement to the Water shader, adding life to your 3D scenes with animated rivers, lakes,
pools, seasâ¦
Communication
from a new technology for export plug-ins. This new feature, which is available in the OBJ, FBX, U3D, DWF, and SKP formats,
OS : Win XP/2000/Vista/Win 7
Language : Multilingual
Filesonic.com Fileserve.com Rapidshare.com Hotfile.com
I will check, If link die, I will reupload at here
Download Filesonic
n process.
delete them.
Media
Layers
Layer Management
Automatic Placement
Layer Import
Visibility by View
same document.
Lights
Fall-off Presets
Neon Shader
Radiosity
Exceptional Quality
Complete Settings
Animation
(Artlantis Studio)
Clouds
Water
pools, seasâ¦
Communication
http://tinypaste.com/a5c7b8
Download Filesonic
http://www.filesonic.com/file/1170945514/AS.v3.0.6.Port.rar
