Antivirus LiveCD 8 in 1 [25.05.2011]
  • Konuyu başlatan Konuyu başlatan haingoc
H
haingoc
Guest
Antivirus LiveCD 8 in 1 [25.05.2011] | 1.5 GB
Here, I decided to do a little assembly Antivirus in one place, from popular and not so. All versions up to date - May 25, 2011!
Ingredients:
1. DrWeb LiveCD 6.00 (163 MB)
Disk System Recovery
If the actions of malicious programs made it impossible to boot a computer running Windows or Unix, reset the affected system for free using Dr.Web LiveCD!
Dr.Web LiveCD will not only clean your computer from becoming infected and suspicious files, but also to copy sensitive information to removable media or another computer, as well as attempts to disinfect infected objects.
2. Kaspersky Rescue Disk 1910 (217 MB)
Kaspersky Rescue Disk 10 - Special program designed to scan and disinfect infected x86 and x64-compatible computers. The program is used when the extent of infection, when it is not possible to cure your computer with antivirus programs or tools of treatment (eg, Kaspersky Virus Removal Tool), running under the operating system.
The effectiveness of treatment is enhanced by the fact that in the system are malicious programs do not get control at boot time. While disaster recovery is available only to the problem of testing facilities and update databases, as well as roll back updates and statistics.
3. AVG Rescue CD (92 MB)
AVG Rescue CD - antivirus boot disk for recovery of Windows-systems that are unable to boot own or have lost this ability due to virus infection or malicious software.
4. Bitdefender Rescue CD (362 MB)
BitDefender Rescue CD scans and removes viruses and other malicious software on all hard drives before the operating system to load Windows. Boot disk for recovery is used when the system can not be loaded or not working properly because the computer is infected with malware. This can happen if the computer was not installed antivirus.
5. Avira Antivir Rescue System (226 MB)
Avira Antivir Rescue System allows users to access data stored on your computer if you can not boot the system. Thus, with the help of this program, you can:
? restore a damaged system,
? save data
? scan for viruses and malicious programs.
6. ESET LiveCD (201 MB)
LiveCD ESET NOD32 - a boot disk with which you can quickly start your computer and recover the incapacitated operating system.
In addition, LiveCD ESET NOD32 will guarantee to remove viruses, potentially dangerous files and sophisticated malicious software, which failed to neutralize in normal mode.
7. F-Secure Recue-CD 3.11 (120 MB)
F-Secure Rescue CD - antivirus rescue disk based on the operating system Linux, scans your computer and installs the extension. Virus for all files containing malware.
8. Vba32 Rescue
This product allows you to disarm the malicious (and suspicious) software on the user's computer with the greatest effect. The scanning and treatment are made regardless of the operating system installed on your computer. Due to this, the malware will not be able to counteract the process of neutralization.
User
1. Format the USB drive the program Hpusbfw.exe the file system FAT32.
Hpusbfw.exe program will also make flash drive bootable.
2. Unzip the contents of the distribution at the root of your stick.
3. Restart your computer and select in the BIOS to boot from USB or click Startup F10 (F2, F12 or another key to select the boot device - depends on the motherboard).
If for any reason your flash drive did not boot, you can try to do the following:
1). Download http://download.gna.org/grubutil/grubinst-1.1-bin-w32-2008-01-01.zip
2). Apply grubinst_gui.exe to stick
Year: 2011
Version: 1 Build 0
Developer: Various
Bit depth: 32bit
Compatible with Windows 7: full
System requirements: PC-compatible computer
http://www.filesonic.com/file/1158082564/Anti....8in1.part1.rar
http://www.filesonic.com/file/1158082634/Anti....8in1.part2.rar
http://www.filesonic.com/file/1158087774/Anti....8in1.part3.rar
http://www.filesonic.com/file/1158078224/Anti....8in1.part4.rar
