Amstrad CPC (464, 664, 6128) konnektör pinout
To connect the converter to the Amstrad CPC, you just have to connect each signal cable directly to the corresponding pin of the monitor connector of the CPC. Have a look at the pinout of the connector. I also added an image from my soldered connector, which might help you building your own connector.
Amstrad Plus (464+, 6128+, GX4000)
Video cable
CPC 464 has a very good RGB signal so the plan was to make a monitor cable that would feed the signal to the TV via a SCART connector.
Connection schematic is below.
