Customization:
This is a fully customizable release, you can easily change Bar Color, Text Color, URL Color, Board Title and Starting Year, as per detail given below:
1. Bar Color Bar color has gradient effect so it requires two related color codes called "First Color" and "Last Color", you can do that with editing the following phrases:
itd_acbff_first_color
(put hex color code like #ffffff)
itd_acbff_last_color
2. Text Color Edit phrase
itd_acbff_text_color
and put required color hex code.
3. URL Color You can also change the URL color too, just edit phrase
itd_acbff_url_color
4. Board Title Instead to use default board title, you can use your selected text as board title, just edit phrase
itd_acbff_board_title
5. Starting Year you must need to change the year since your board online, so just edit phrase
itd_acbff_starting_year
and write appropriate year.
