Add Password Protection
There are many instances requiring the user to be prompted for information that must not be visible on the screen, such as a password. In AutoPlay Media Studio this is accomplished by using a Dialog.PasswordInput action.
As an example, we will prompt the user for a password at the start of your program, and compare it to a stored value (thereby limiting access to your program to only those who know the password).
To accomplish this:
  1. Insert the following script in your page's On Show event:
-- the 'correct' password
real_password = "password";
-- prompt the user to enter a password
user_password = Dialog.PasswordInput("Password", "Please enter the password: ", MB_ICONQUESTION);
-- compare the user's password to the 'correct' password.
-- If the user supplies the wrong password, exit the program.
if real_password ~= user_password then
    Application.Exit();
end
This script pops up a dialog box requesting the password. Whatever the user types in this dialog box appears as *******. If the correct password is entered, the program runs normally. If any other password is entered, the program will close.
Alternatively, you can have a 'list' of valid passwords. To accomplish this, store your valid passwords in a table:
--assume the user enters a bad password
correct_password = false;
real_passwords = {"password", "password2", "3rdPassword"};
for j in real_passwords do
    if real_passwords[j] == user_password then
        correct_password = true;
    end
end
--if the password was bad, exit
if not correct_password then
    Application.Exit();
end
