ABACOM Sprint-Layout 5.0
With Sprint-Layout you can design your PCB’s quick and easy. There is no unnecessary “ballast” which makes it difficult to keep the overview or which makes the usage almost impossible. Because of the logical and understandable strucure of Sprint-Layout the usage is very easy to learn. So finally you can concentrate to the essential thing: Designing and optimizing your PCB-layouts.
Sprint-Layout offers all needed functions to design your own layouts. Of course there is an extensive library with all common components included.
For manufacturing your PCB’s by hand there is an excellent printout-procedure with many options available. If you want to produce professional boards there are many PCB-manufacturer which accept Sprint-Layout files. If required you can export your layout to the GERBER and EXCELLON format. Sprint-Layout is also able to create HPGL files for isolation-milling.
ABACOM Sprint-Layout 5.0 Full Download [4.50 MB]
http://www.mediafire.com/file/w3nd2ianwj08uu4/Sprint_Layout_5.0_FULL_%26_Huong_dan_su_dung.rar/file
Sprint-Layout Full v6.0 İndir
Sprint-Layout, ile pcb tasarlama devre yapma oluşturma programıdır dilediğiniz pcb tasarlamanıza olanak tanır
isoyu açıp kurun full olduğu yazmakta, baktınız sorun oldu ek aktivasyonda eklenmiştir.
Boyut:9-mb
Update dosyası içinde yer almaktadır sadece kurulum yapınız. Program güncelleme isterseniz kendi üzerinden yapabilirsiniz.​
