6 - 12 Volt audio amplifier
uydudoktoru
Yönetici
Yönetici
The above is an amplifier circuit using supply voltages from 6 volts DC to 12 Volt DC. Power output of the amplifier is quite low with only 1 Watt 8 ohm impedance. You canapply this to the audio signal amplifiers that require strengthening are not so large as in the pocket radio.
Part List :
R1 = 100K
R2 = 39R
R3 = 100R
C1 = 100nF
C2 = 100uF
C3 = 100uF
C4 = 100uF
C5 = 470uF
C6 = 100nF
C7 = 68pF
C8 = 1nF
C9 = 47uF
IC = SFC2790C
