DC-DC converter printed circuit board
Using the TPS61087 integrated circuit from Texas Instruments you can build a high efficiency power supply with just few electronic components. This step up converter circuit can provide an output regulated voltage up to 18.5 volts and 0.3A load current for inputvoltages between 2.5 and 6 volts. The components from the follow circuit diagram are calculated for a 5V output voltage, using a lithium polymer battery for supply.
DC-DC converter schematic
The output voltage can be calculated using this formula:
Vout=1,238Vx(1+R2/R3)
For R3=18k and R2=56k we have Vout=5.089V, if R2=47k then Vout will be 4.47V.For low output ripple a low ESR ceramic capacitors must be used. The C4 capacitor connected to the soft start pin minimizes inrush current at startup. The thermal shutdown is triggered at a junction of 150°C, preventing damages due to excessive heat. A NiZn core toroid for L1 inductor can be found in electronic ballast of some CFL ( Compact fluorescent Lamp ).
Downloadcircuit schematic in pdf format from here.
