5V/3A Regulator
5V / 3A Regulator devresi
This regulator power supply schematic diagram is the same as the previous 5V 10A regulator circuit with a little modification and have the ability to supply less current up to 3 amperes at voltage of 5V.
The circuit is built from a complete 5V regulator IC LM 109 series from National Semiconductor. While for the current amplifier using a PNP type transistor MJE 370.
5 V / 10 A REGULATOR Parts list :
R : 1 ohm 3W, 2 ohm 5W
C : 0.22uF, 10 uF
Semiconductor : LM109 K, MJE 370 ( PNP )
Features​
  • Low Resistance Pass Transistor: 0.25Ω
  • Dropout Voltage: 0.75V at 3A
  • ±1% Reference Voltage
  • Accurate Programmable Current Limit
  • Shutdown Capability
  • Internal Reference Available
  • Full Remote Sense
  • Low Quiescent Current: 2.5mA
  • Good High Frequency Ripple Rejection
  • Available in 5-Lead TO-220 and DD Packages
