45W Single Chip Amplifier by LM3876
This circuit is based on the National Semiconductor LM3876. This device is capable of delivering as much as 56W of continuous average power into an eight ohm load with 0.1% THD from 20Hz to 20Khz. Be sure to provide an adequate heat sink for the package.
Use log pots for volume, bass and treble. A stereo amplifier can be built using ganged pots and a Stancor 402 transformer instead of the 401.
Note that the delivery of power to the speakers is primarily a function of the power supply voltage and capacity in Class A amplifier. In our case, we’re using a +/- 33 volt volt supply which is designed around a Stancor RT401 transformer. Use extreme caution when working with line voltages
LM3876 Gainclone Amplifier
The amp is based on the Project 19 PCB, so uses a pair of LM3876 (or LM3886) power opamps, run from a ±35V supply. I used a cut-down P88 preamp PCB because I only wanted one preamplifier stage, but the entire board can also be used. Alternatively, the P19 amp can be run at higher gain than normal, alleviating the need for a preamp at all. The down side of this is that the noise level will be higher, and background noise may be audible with efficient speakers and/ or very quiet surroundings.
