350w Studio Amplifikatör Devre Şeması
Specifications
Output Power 200W into 8 Ohm; 350W into 4 Ohm
Music Power 240W into 8 Ohm; 480W into 4 Ohm
Frequency Response -1dB at 15Hz and 60kHz at 1W
Input Sensitivity 1.75V for 200W into 8 Ohm
Harmonic Distortion Typically .002% at normal listening levels
Signal-to-Noise Ratio -122dB unweighted (22Hz to 22kHz); -125dB
A-weighted, both with respect to 200W into 8 Ohm
Damping Factor <180 at 100Hz; <75 at 10kHz, with respect to 8 Ohm
Protection 5A supply fuses
Stability Unconditional
  • Amplificador de audio studio 350 vercion 1.zip
    86,8 KB · Görüntüleme: 84
