DIY Electronic circuit today,I take the 30A speaker protection circuit .
This circuit has two relay for switch function connect before speaker input signal.
circuit function is recieved AC signal pass to capacitor for current smoothly then the diode bridge will full wave for convert to DC power before supply to transistor 2N3904 that is current checker and switch to drive BD139
transistor for drive these relay.
You does not worry to build this project as we have completely schematic and PCB that can copy to make the real PCB.
Electronic Parts List
Transistor : 2N3904 2 pcs.
Transistor : BD139 1 pcs.
Capacitor : 100uF / 30 V 2 pcs.
Capacitor : 220uF / 30 V 2 pcs.
Diode : 1N4001 2 pcs.
Diode : 1N1418 4 pcs.
LED 1 pcs.
Resistor : 47K 3 pcs.
Resistor : 1K 1 pcs.Resistor : 10K 1 pcs.
Resistor : 100 ohm 1 pcs.
Resistor : 150K 3 pcs.
Relay 12VDC/30A 2 pcs.
30A Speaker Protection PCB
LED 1 pcs.
