Part | Total Qty. | Description | Substitutions | R1 | 1 | 100K 1/4W Resistor | | R2 | 1 | 820K 1/4W Resistor | | R3, R14, R16, R18 | 4 | 2.2 Meg 1/4W Resistor | | R4, R5, R6 | 3 | 22K Pot | | R7, R8, R9, R25, R27, R29 | 6 | 10K 1/4W Resistor | | R10, R11, R12 | 3 | 680 Ohm 1/4W Resistor | | R13. R15, R17 | 3 | 580K 1/4W Resistor | | R19, R20, R21 | 3 | 39K 1/4W Resistor | | R22, R23, R24 | 3 | 47K 1/4W Resistor | | R26, R28, R30 | 3 | 33 Ohm 1/4W Resistor | | C1, C5, C6 | 3 | 0.012uF Polystyrene Capacitor | | C2, C9, C10, C11 | 4 | 3.3uF Electrolytic Capacitor | | C3, C4 | 2 | 0.0022uF Polystyrene Capacitor | | C7, C8 | 2 | 47nF Polystyrene Capacitor | | C12, C13, C14 | 3 | 0.47uF Electrolytic Capacitor | | C15, C16, C17 | 3 | 22uF Electrolytic Capacitor | | D1, D2, D3 | 3 | 1N4002 Silicon Diode | | D4, D5, D6, D8, D8 | 5 | Green LED | | D10, D11, D12, D13, D14 | 5 | Amber LED | | D16, D17, D18, D19, D20 | 5 | Red LED | | U1 | 1 | LM3900 Quad Op Amp | | U2, U3, U4 | 3 | AN6884 Bar Graph IC | | MISC | 1 | Board, Wires, Sockets For ICs | |
Notes:1. The circuit expects line level inputs. If you connect it to speaker level, you will have to readjust the circuit every time you change the volume.
2. After the circuit is connected, apply power and signal. Now adjust the pots until the corresponding group of LEDs reacts.
