TRASMETTITORE FM 88-108
Konusu 'Fm Verici Devreleri' forumundadır ve guclusat tarafından 3 Kasım 2017 başlatılmıştır.
    COMPONENTI:
    R1: RESISTENZA DA 1KW
    R2-6: RESISTENZE DA 10KW
    R3-4-9: RESISTENZE DA 100KW
    R5: RESISTENZA DA 120KW
    R7-8: RESISTENZE DA 180KW
    R10: RESISTENZA DA 82KW
    R11: RESISTENZA DA 47KW
    R12: RESISTENZA DA 22KW
    R13: RESISTENZA DA 22W
    TUTTE LE RESISTENZE SONO DA ¼W E AL 5%
    JAF1: IMPEDENZA ASSIALE DA 10H 0 22H
    DV1: DIODO VARICAP BB405
    CV1: COMPENSATORE MICROMINIATURA DA 2÷22pF
    C1-2: COND. MULTISTRATO DA 100F
    C3: COND. CER. DA 22pF
    C4: COND. CER. DA 8,2pF
    C5: COND. CER. DA 10pF
    C6: COND. CER. DA 56pF
    L1: BOBINA IN RAME ARGENTATO DA 1mm COMPOSTA DA 4 SPIRE SU DI UN DIAMETRO INTERNO DI 6,5mm E UNA LUNGHEZZA TOTALE DI 10mm
    U1: INTEGRATO LM358
    T1-2: TRANSISTOR 2N2222A
    M1: CAPSULA MICROFONICA PREAMPLIFICATA
    ANTENNA: FILO DI QUALSIASI TIPO (IN RAME) LUNGO 55cm
    N°1 ZOCCOLO A 8 PIN
    N°1 CLIP PER PILA DA 9V
    VL: 9VL
