JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Son kullanma tarihi geçmiş, bayatlamış bir tarayıcı kullanıyorsanız. Mercedes kullanmak yerine tosbaya binmek gibi... Websiteleri düzgün görüntüleyemiyorsanız eh, bi zahmet tarayıcınızı güncelleyiniz.
Modern Web standartlarını karşılayan bir tarayıcı
alternatifine göz atın .
TDA8954TH amplifikatör devre şeması 2x 210W
BOM TO ASSEMBLE TDA8954TH AMPLIFIER CIRCUIT
Part Value Description Quantity Resistors 1/4W R1, R2 220 (221) SMD resistor 0805 5% 2 R3, R4, R18 0 (0) SMD resistor 0805 5% 3 R5, R6, R7, R8, R31, R32 5.6K (562 or 5601) SMD resistor 0805 1% 5 R9, R10, R13, R14 10R (10R0 or 100) SMD resistor 1206 1% 4 R11 30K (303 or 3002) SMD resistor 0805 1% 1 R12 10 (10R0 or 100) SMD resistor 0805 5% (optional) 1 R15, R16 22 ohms 3W resistor 2 R17, R25, R26, R28, R29 10k (103) SMD resistor 0805 5% 5 R27, R30 1k (102) SMD resistor 0805 5% 2 R34 12k (123) SMD resistor 0805 5% 1 Capacitors C1, C2 100p/50V SMD Ceramic capacitor 0805 NP0 2 C3, C4 470µ/63V Electrolytic capacitor 2 C5 22µF/160V Electrolytic capacitor 1 C6, C7, C8, C9, C16 470n/63 or 100V (474) Polyester Capacitor 5 C10, C11 330p SMD Ceramic capacitor 0805 NP0 2 C12, C13 220n SMD Ceramic capacitor 0805 X7R 2 C14, C25, C26, C27, C28 220p/100V SMD Ceramic capacitor 0805 NP0 5 C15, C35 100n SMD Ceramic capacitor SMD 0805 2 C17, C18, C19, C20, C21, C22, C31, C32 100nF/100V SMD Ceramic capacitor 1206 X7R 8 C23, C24, C33, C34 15n/100V SMD Ceramic capacitor 0805 X5R 4 C29, C30 680n/63 ou 100V (684) Polyester Capacitor 2 C39 100uF/25V Electrolytic capacitor 1 Semiconductors DZ1 5V6 – Zener 5.6V 500mW SMD LL-34 Zener diode 1 DZ2 7V5 – Zener 7.5V 500mW SMD LL-34 Zener diode 1 D1, D2, D3, D5 US1MG or equivalent Fast Recovery Diode 1kV 1A SMA 4 IC1 TDA8954TH Class D Audio Amplifier Integrated Circuit – NXP Semiconductors 1 LED1 TEMP LED3MM 1 LED2 ALARM LED3MM 1 Q1 MBT5551 (G1) or equivalent SOT23 NPN -160V SMD transistor 1 Q2, Q3 S9015 (M6) or equivalent SOT23 -50V SMD NPN transistor 2 Connectors DC Terminal block 3 pin 5.08 mm DC power supply 1 INL Terminal block 2 pin 5.08 mm Left audio input 1 INR Terminal block 2 pin 5.08 mm Right audio input 1 OUTL Terminal block 2 pin 5.08 mm Left audio output 1 OUTR Terminal block 2 pin 5.08 mm Right audio output 1 Miscellaneous L1, L2 22µH Toroidal Coil 10A 2
