STK 4192 Power Amplifier
STK 4192 Power Amplifier Circuit
Features
AF Power Amplifier (Split Power Supply)
(50W + 50W min, THD = 0.4%)
• The STK4102II series (STK4192II) and STK4101V
series (high-grade type) are pin-compatible in the output
range of 6W to 50W and enable easy design.
• Small-sized package whose pin assignment is the same
as that of the STK4101II series
• Built-in muting circuit to cut off various kinds of pop
noise
• Greatly reduced heat sink due to substrate temperature
125°C guaranteed
• Excellent cost performance
PARTS LIST
R1 56KΩ
R2 56KΩ
R3 1KΩ
R4 1KΩ
R5 560Ω
R6 560Ω
R7 100Ω
R8 100Ω
R9 56KΩ
R10 56KΩ
R11 3.3KΩ
R12 3.3KΩ
R13 3.3KΩ 0.5W
R14 3.3KΩ 0.5W
R15 4.7Ω
R16 4.7Ω
R17 1KΩ 0.5W
R18 1KΩ 0.5W
C1 400pF
C2 400pF
C3 2.2µF
C4 2.2µF
C5 100µF
C6 100µF
C7 0.1µF
C8 0.1µF
C9 10µF
C10 10µF
C11 47µF
C12 47µF
C13 100µF
C14 10µF
RL1 100W 8Ω
RL2 100W 8Ω
IC STK4192II
Power Supply
PARTS LIST
D1 5A Diode
D2 5A Diode
D3 5A Diode
D4 5A Diode
R1 500Ω 2W
R2 500Ω 2W
C1 10000µF 63V
C2 10000µF 63V
T1 32-0-32 Volts 5 Amps Transformer
STK4192II stereo amplifier IC
Specifications
Maximum supply voltage (Vcc max) ±52.5V
Recommended supply voltage (Vcc) ±35V
Recommended Load resistance (RL) 8Ω
Typical Muting voltage –5V (Min: –2, max: –10)
Input impedance (Conditions: Output power 1W, Frequency 1kHz) 55 kΩ
