Son kullanma tarihi geçmiş, bayatlamış bir tarayıcı kullanıyorsanız. Mercedes kullanmak yerine tosbaya binmek gibi... Websiteleri düzgün görüntüleyemiyorsanız eh, bi zahmet tarayıcınızı güncelleyiniz. Modern Web standartlarını karşılayan bir tarayıcı alternatifine göz atın.
KENDİME AİT SONY MARKA KV29FX66E MODEL AE-6B ŞASE TELEVİZYONUM VAR. ÖNCE STERO HOPERLÖR GÖRÜNTÜSÜ YAPARAK SESİ KESTİ, AÇIP KAPANINCA DA STANDBY LEDİ ALTI(6) DEFA YANIP SÖNÜYOR. SES ENTEGRESİ OLAN TDA7497'Yİ DEĞİŞTİRDİM AMA SONUÇ DEĞİŞMEDİ. ARIZA KODU OLARAK " IIC bus clock and/or data lines low at power on" ANLAMINA GELDİĞİNİ USER MANUEL'İNDEN ÖĞRENDİM. NASIL TAMİR ETMEM GEREKTİĞİ KONUSUNDA BANA YARDIM EDEBİLECEK ARKADAŞLAR ARIYORUM.
Benim yaptığım araştırmada ise programlama yapmanız gerekebilir yazıyor.
The identification of errors within this chassis is triggered in one of two ways. Busy or Device failure to respond to II2 IC.
TO ENTER INTO ERROR TABLE
Turn On the main Power switch of the TV set.
Program Remove commander for Operation in Service mode.
Press 'AUX/VIDEO' 'AUX/VIDEO > MENU' on the remote commander.
Using the remote commander, scroll to the 'Error' item using the down arrow key.
Table-2 will be displayed.
LED blinking codes:
Error message
LED Blinking Code
No error
00
Reserved
01
OCP [Over Voltage Protection]
02
03
No Vertical Sync.
04
IKR Error at power On
05
IIC bus clock and / or data lines low at power On.
06
NVM no IIC bus acknowledge at Power On.
07
Horizontal protection
08
Tuner no acknowledge at Power On.
09
Sound Processor error
10
Reserved
11
Scanrate Error
12
DAC Error
13
Backend Error
14
Dynamic Convergence Error PIP Error
15 16
[Programming the remote commander for Operation in Service Mode]
Press & Hold the left Mode Select button, until the VCR and DVD LEDs flash.
Press '99999'. The TV LED should light. The remote commander is now set to Service Mode.
To return the remote commander to normal operation mode, repeat step-1, then press '00000'. The TV LED should light. The remote commander is now set to normal mode.
[Setting the TV into Service Mode]
Program the remote commander for operation in ServiceMode as described above.
Turn On the TV main Power switch.
Press the 'Aux/Video' standby button on the remote controller Twice. "TT" will appear in the upper right corner of the screen. Other status information will also be displayed.
Press "Menu" on the remote commander to obtain the service mode screen.
Move the corresponding adjustment item using the Up / Dn arrow buttons on the remote control.
Press (>) button to enter into the required menu item.
Press 'Aux/Video' button on the remote control to QUIT the service mode, after all adjustments have been done.
Switch the TV set OFF and then switch it ON again.
