PLEASE READ THE INSTRUCTION:
STEP 1: Install "Electrical calculations FREE app" (Important: without FREE version, the Pro Key does not work!)
STEP 2: Now install this Pro Key to unlock all new features.
STEP 3: Reboot your device after installation, does not remove the FREE app.
DO NOT USE THE RATING SYSTEM TO REPORT BUGS!
INSTEAD CONTACT ME ON: gallinaettore84@gmail.com
This app is essential for an electrician
Calculation of section
Calculation of voltage drop
Calculation of intensity
Calculation of active power
Calculation of apparent power [PRO]
Calculation of reactive power [PRO]
Calculation of resistance
Conversion Hp/KW
Calculation of capacitor for single-phase motor
Conversion AWG/mmq
Code resistors with 4 colors
Code resistors with 6 colors [PRO]
Code inductor [PRO]
Show colors resistor from its value
Fuses
Sum of resistors
Sum of capacitors [PRO]
Resistance to reduce voltage
Resistance for led
Power factor correction [PRO]
Calculation rpm motor [PRO]
Calculation of short circuit current [PRO]
Current carrying capacity of cables [PRO]
Table of resistivity [PRO]
Battery life [PRO]
Electrical symbols [PRO]
Fault current of strings [PRO] (by: Ing. Arnaldo Armida)
IP Protection Classes
Conversion Δ-Y [PRO]
Antenna length [PRO]
Conversion cm/inch
Electricity around the World
Joule Effect [PRO]
Ethernet wiring (RJ-45) [PRO]
Pinout RJ-11,14,25,48 [PRO]
Pinout Scart [PRO]
Pinout USB [PRO]
Pinout HDMI [PRO]
Pinout VGA [PRO]
Pinout DVI [PRO]
Pinout RS-232 [PRO]
Pinout Molex [PRO]
Pinout GPIO Raspberry [PRO]
Others languages:
- Italian (by Ettore Gallina)
- Français (by Yves Tschantz)
- Espanol (by Marcela Rodriguez)
- Portoguese (by José Machacaz, Moacir Carvalho)
- Arabic (by Ghassan Al_dahab)
- Polish (by RaV)
- Deutsch (by Diego Maggi, Claudio Ruffino)
- Greek (by Tasos Pergantis)
- Latvian (by Witold Džeriņš)
- Romanian (by Lucian Voica)
- Turkish (by Emrah HARMANBAŞI)
- Russian (by Leonid Tsvetinovich)
- Dutch (by Ilyahoo Proshel)
- Magyar (by Oláh-Szőnyi Csaba)
- Croatian (by Pero Razović)
- Malay (by Nazrul Afdhal)
- Persian (by Behnam Eskandariun)
Download APK:
http://dl.globalapk.com/2014/05/Electrical calculations PROKey v3.1.1.apk
Google Play Store:
https://play.google.com/store/apps/details?id=it.Ettore.calcolielettriciPRO
