DipTrace Türkçe v3.0.0.1 Full
Konusu 'Elektronik programlar / Electronic programs' forumundadır ve guclusat tarafından 13 Eylül 2017 başlatılmıştır.
    DipTrace,32×64 bit bir çok dili destekleyen güçlü şema çizim ve pcb tasarım programıdır DipTrace çeşitli proje ve
    şemalar ile dilediğinizi tasarlayıp,iş akışlarınıza hız katabilirsiniz.
    Boyut:7-gb
    DipTrace
    DipTrace
    DipTrace
    Son düzenleme: 23 Şubat 2018
    DIPTRACE 3.0 X86 / X64 3.0.0.1 X86 X64
    7.01 GB
    Bit depth: 32bit, 64bit
    Language: Multilingual
    Medicine: Present
    System requirements:
    - OS: Windows XP / Vista / 7/8 / 8.1 (32, 64-bit); Linux (Wine); Mac OS X (requires XQuartz X11).
    - Processor: 1 GHz Pentium III or equivalent;
    - RAM: 1 Gb;
    - 1,5 Gb of free hard disk space;
    - Screen resolution at least 1024x768;
    - OpenGL / DirectX 9.0 or higher.
    Schematic Capture is an advanced circuit design tool with support of multi-sheet and multi-level hierarchical schematics. This module of DipTrace delivers a number of features for visual and logical pin connections. Cross-module management ensures that principal circuits can be easily converted to PCB, back annotated, or imported/exported from/to other EDA, CAD, and netlist formats. Verification and Spice export for simulation allow for full project analysis.
    PCB Layout is a high-level engineering tool for board design featuring smart manual routing with differential pair support, shape-based autorouter, advanced verification, and wide import/export capabilities. Design requirements are defined by net classes, class-to-class rules, and detailed settings by object types for each class or layer. DipTrace features design process with real-time DRC, which reports errors on the fly before actually making them. The board can be previewed in 3D and exported for mechanical CAD modeling. Design Rule Check with in-depth detailing, Net Connectivity verification, and comparing to source schematic ensure maximum quality of the final product.
    DipTrace is always up-to-date; we continuously expand component libraries and bring innovations directly to you. The standard library set already includes more than 130,000 components and 15,200 patterns. Pattern and Component Editors allow you to design new components with custom templates, bulk pin naming, pad renumbering, and bus management instruments, which significantly increase the working speed. Importing libraries and 3D models from various formats adds even more engineering capabilities. Component and Pattern library verifications ensure an error-free design environment from the early beginning.
    DipTrace PCB Layout module includes real-time 3D preview & export feature. It shows the model of manufactured printed circuit board with all components installed. You can rotate the board in three axes, zoom in and out in real time, change colors of the board, copper areas, solder mask, silkscreen, and background. 3D preview works on all stages of the design. Board can be exported to STEP or VRML 2.0 formats for mechanical CAD modelling. More than 6500 3D models of PCB packages are supplied for free. Externally designed 3D models in *.wrl, *.step, *.iges, and *.3ds formats can be uploaded and attached to patterns in Pattern Editor or PCB Layout.
    Installing on a Mac:
    1. Download and install XQuartz from xquartz.macosforge.org. There
    Also you will find all the necessary instructions for installing XQuartz.
    2. Restart the computer, or restart to the system to complete the XQuartz installation.
    3. Download and open the DipTrace DMG file.
    4. Add DipTrace to the Applications folder.
    5. Start and use DipTrace!
    User name: For non-commercial use
    Reg. key: HW9S-PDTN-T5MA-HPXE
    http://besttorrent.org/_ld/36/3630_DipTrace_3.0_x8.torrent
