4 x 35W Anfi devresi TDA7384A
Konusu 'Amplifikatör Devreleri' forumundadır ve guclusat tarafından 18 Ekim 2016 başlatılmıştır.
Etiketler:
    Features
    • High output power capability:
    • 4 x 46 W / 4 max.
    • 4 x 27 W / 4 @ 14.4 V, 1 kHz, 10 %
    • Low distortion
    • Low output noise
    • Standby function
    • Mute function
    • Automute at min. supply voltage detection
    • Low external component count:
    • Internally fixed gain (26 dB)
    • No external compensation
    • No bootstrap capacitors
    • Protections:
    • Output short circuit to GND, to VS, across
    • e load
    • Very inductive loads
    • Overrating chip temperature with soft
    • ermal limiter
    • Load dump voltage
    • Fortuitous open GND
    • Reversed battery
    • ESD
    Description
    The TDA7384A is an AB class audio power amplifier, packaged in Flexiwatt 25 and designed
    for high end car radio applications. Based on a fully complementary PNP/NPN configuration, the TDA7384A allows a rail to rail output voltage swing with no need of bootstrap capacitors. The extremely reduced boundary components count allows very compact sets.
Benzer Konular - 35W Anfi devresi
  3. uydudoktoru
  5. uydudoktoru
