32w hı-fı audıo power amplıfıer - tda2050
Konusu 'Amplifikatör Devreleri' forumundadır ve guclusat tarafından 9 Kasım 2011 başlatılmıştır.
    The TDA 2050 is a monolithic integrated circuit in Pentawatt package, intended for use as an audio class AB audio amplifier. Thanks to its high power capability the TDA2050 is able to provide up to 35W true rms power into 4 ohm load @ THD = 10%, VS = ±18V, f = 1KHz and up to 32W into 8ohm load@ THD = 10%, VS = ±22V, f = 1KHz.
    Moreover, the TDA 2050 delivers typically 50W music power into 4 ohm load over 1 sec at VS= 22.5V, f = 1KHz.
    The high power and very low harmonic and crossover distortion (THD = 0.05% typ, @ VS = ±22V, PO = 0.1 to 15W, RL=8ohm, f = 100Hz to 15KHz) make the device most suitable for both HiFi and high class TV sets.
    • HIGH OUTPUT POWER (50W MUSIC POWER IEC 268.3 RULES)
    • HIGH OPERATING SUPPLY VOLTAGE (50V)
    • SINGLE OR SPLIT SUPPLY OPERATIONS
    • VERY LOW DISTORTION
    • SHORT CIRCUIT PROTECTION (OUT TO GND)
    • THERMAL SHUTDOWN
    PARTS LIST
    R1----22K
    R2----680
    R3----22K
    R4----2.2
    C1----1mf
    C2----22mf
    C3----100nf
    C4----100nf
    C5----220mf
    C6----220mf
    C7----0.47mf
    IC----TDA2050
  2. samyadas
    samyadas Yeni Üye Kayıtlı Üye
    21 Mart 2012
    bu kondansatörler kaç volt olması gerekiyor???
    63 volt taksan yeterli olur arkadaşım
    Maybe anyone want assemble a mini amps for rooms audio? IC-Amp TDA2050 maybe this one can be a choice. besides the price is very affordable as well sound produced can spoil our ears. said the IC-Amp TDA2050 one is a rival LM1875 (though still better LM1875). This circuit scheme and pcb layout :
    TDA2050 Power Amplifier Circuit
    TDA2050 Power Amplifier Circuit High output power, low distortion, HiFi power amplifier for your home audio system. Maximum output at 4 ohm speaker is 35 watts, while the 8 ohm speaker is only 15 watts. This circuit must use a good power supply so that the sound quality could be as expected.
    TDA2050 Power Amplifier Circuit Schematic
    Output 50W RMS(4 ohm) / 32WRMS (8hm ) Hi-Fi AUDIO POWER AMPLIFIER
    List of components:
    Resistors 1, 2, 3, 4: 22K ohm
    5 resistor: 2.2 ohm
    Capacitor 1: 100uF/50V
    Capacitor 2: 2.2uf/50V
    Capacitor 3: 22uF/50V
    Capacitor 4: 0.47uF
    Capacitor 5: 1000uF/50V
    Capacitor 6: 100nF
    Capacitor 7: 1000uF/50V
    IC: TDA2050
