22 Watt Car Subwoofer Amplifier
Konusu 'Amplifikatör Devreleri' forumundadır ve uydudoktoru tarafından 19 Şubat 2016 başlatılmıştır.
    This unit is intended to be connected to an existing car stereo amplifier, adding the often required extra "punch" to the music by driving a subwoofer. As very low frequencies are omnidirectional, a single amplifier is necessary to drive this dedicated loudspeaker. The power amplifier used is a good and cheap BTL (Bridge Tied Load) 13 pin IC made by Philips (now NXP Semiconductors) requiring a very low parts count and capable of delivering about 22W into a 4 Ohm load at the standard car battery voltage of 14.4V.
    Parts:
    P1_____________10K Log Potentiometer
    P2_____________22K Dual gang Linear Potentiometer
    R1,R4___________1K 1/4W Resistors
    R2,R3,R5,R6____10K 1/4W Resistors
    R7,R8_________100K 1/4W Resistors
    R9,R10,R13_____47K 1/4W Resistors
    R11,R12________15K 1/4W Resistors
    R14,R15,R17____47K 1/4W Resistors
    R16_____________6K8 1/4W Resistor
    R18_____________1K5 1/4W Resistor
    C1,C2,C3,C6_____4µ7 25V Electrolytic Capacitors
    C4,C5__________68nF 63V Polyester Capacitors
    C7_____________33nF 63V Polyester Capacitor
    C8,C9_________220µF 25V Electrolytic Capacitors
    C10___________470nF 63V Polyester Capacitor
    C11___________100nF 63V Polyester Capacitor
    C12__________2200µF 25V Electrolytic Capacitor
    D1______________LED any color and type
    Q1,Q2_________BC547 45V 100mA NPN Transistors
    IC1___________TL072 Dual BIFET Op-Amp
    IC2_________TDA1516BQ 24W BTL Car Radio Power Amplifier IC
    SW1____________DPDT toggle or slide Switch
    SW2____________SPST toggle or slide Switch capable of withstanding a current of at least 3A
    J1,J2__________RCA audio input sockets
    SPKR___________4 Ohm Woofer or two 8 Ohm Woofers wired in parallel
    Circuit description:
    The stereo signals coming from the line outputs of the car radio amplifier are mixed at the input and, after
    the Level Control, the signal enters the buffer IC1A and can be phase reversed by means of SW1. This control can be useful to allow the subwoofer to be in phase with the loudspeakers of the existing car radio. Then, a 12dB/octave variable frequency Low Pass filter built around IC1B, Q1 and related components follows, allowing to adjust precisely the low pass frequency from 70 to 150Hz. Q2, R17 and C9 form a simple dc voltage stabilizer for the input and filter circuitry, useful to avoid positive rail interaction from the power amplifier to low level sections.
    Notes:
    • IC2 must be mounted on a suitable finned heatsink
    • Due to the long time constant set by R17 and C9 in the dc voltage stabilizer, the whole amplifier will become fully operative about 15 - 30 sec. after switch-on.
    Technical data:
    Output power (1KHz sinewave):
    22W RMS into 4 Ohms at 14.4V supply
    Sensitivity:
    250mV input for full output
    Frequency response:
    20Hz to 70Hz -3dB with the cursor of P2 fully rotated towards R12
    20Hz to 150Hz -3dB with the cursor of P2 fully rotated towards R11
    Total harmonic distortion:
    17W RMS: 0.5% 22W RMS: 10%
