200 Transistor Circuits
uydudoktoru
Yönetici
Yönetici
Here is a list of the contents:Ammeter 0-1A​
Automatic Garden Light
Automatic Light
Bench Power Supply
Boom Gate Lights
Boxes
Buck Converter for LEDs 48mA
Buck Converter for LEDs 170mA
Buck Converter for LEDs 210mA
Cable Tracer
Clock - Make Time Fly
Colpitts Oscillator
Constant Current Source
Dancing Flower
Door-Knob Alarm
Dynamic Microphone Amplifier
Electronic Drums
Fog Horn
FRED Photopopper
Gold Detector
Guitar Fuzz
Hartley Oscillator
Heads or Tails
Hearing Aid Constant Volume
Hearing Aid Push-Pull Output
Hearing Aid 1.5v Supply
Hee Haw Siren
IC Radio
LED Detects Light
LED Flasher 1-Transistor
LED Torch with Adj Brightness
LED Torch with 1.5v Supply
Lie Detector
Light Alarm-1
Light Alarm-2
Light Alarm-3
Light Extender for Cars
Listener - phone amplifier
Make Time Fly!
Making 0-1A Ammeter
Metal Detector
Microphone Pre-amplifier
Motor Speed Controller
Movement Detector
Multimeter - Voltage of Bench Supply
Music to Colour
On-Off via push Buttons
Phaser Gun
Phone Alert
Phone Tape-1
Phone Tape-2
Phone Transmitter-1
Phone Transmitter-2 Phase-shift Oscillator
Resistor Colour Code
Robo Roller
Robot Man - Multivibrator
Schmitt Trigger
SCR with Transistors
Second Simplest Circuit
Signal by-pass
Signal Injector
Simple Logic Probe
Siren
Solar Engine
Solar Engine Type-3
Solar Photovore
Sound to Light
Sound Triggered LED
Speaker Transformer
Spy Amplifier
Strength Tester
Sun Eater-1
Sun Eater-1A
Super Ear
Ticking Bomb
Touch Switch
Train Throttle
Transistor Pinouts
Transistor Tester-1
Transistor Tester-2
Trickle Charger 12v
Walkie Talkie
Walkie Talkie - 5 Tr - circuit 1
Walkie Talkie - 5 Tr - circuit 2
Worlds Simplest Circuit
White LED Flasher
White LED with Adj Brightness
White Line Follower
Zener Diode (making)
0-1A Ammeter
5 LED Chaser
5 Transistor Radio
6 Million Gain
6 to 12 watt Fluoro Inverter
12v Relay on 6v
12v Trickle Charger
20watt Fluoro Inverter
27MHz Door Phone
27MHz Transmitter
27MHz Transmitter - no Xtal
27MHz Transmitter-Sq Wave
27MHz Transmitter-2 Ch
27MHz Receiver
27MHz Receiver-2
303MHz Transmitter
