12V 3A Power Supply Circuit
Yapımı kolay ve bir kaç malzemeden oluşan güçlü bir besleme devresidir.. 12V 3A Power Supply Circuit​
This circuit provides a 12V regu-lated power supply with output current up to 3 amperes. It is spe-cially designed for use with 2m handheld rigs with linear power amplifier and CB portable QRP rigs. The circuit uses monolithic IC CA3085 voltage regulator in 8-lead TO-5 package. Its salient features include good load and line regulation, output current up to 100 mA (which can be increased to several amperes with additional pass transistors), output short-circuit protection, and lower input voltage. A low power dissipation is achieved by driving external series-pass transistor 2N4241 (T1) from pin 2 of CA3085.
Circuit diagram :
12V, 3A Power Supply Circuit Diagram
Normal output pin 8 is returned to ground via diodes D3 and D4 to ensure error am-plification operation in the linear region. Ripple rejection is approximately 50 dB on no load and 35 dB on full load. A 2x2x2.5cm aluminium heat sink fas-tened onto a 1.5mm blackened aluminium sheet of 12.5cm2 area on 2N4241 helps the circuit in dissipating heat without ex-ceeding maximum device ratings. CA3085 can dissipate up to 650mW power in free air, without any heat sink. AFCO-make C-05-4 heat sink is suitable for this IC. An improper heat sink may cause device junction temperature to ex-ceed the limit, resulting in progressive deterioration of the device.
Here is circuit Switching power supply 12V 3A. Or circuit dc converterstep down voltage.
Use IC LM2576-12 SIMPLE SWITCHER High Efficiency 3A Step-Down Voltage Regulator.
Input DC Voltage 40Vmax and 16Vmin 3A.
